585,974 active members*
4,318 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Aligning solid models
    Mar 2010
    Question Aligning solid models
    Using Mastercam X2. Just received some models and need to align them to axis. How do I do that? I can't find the information in the book or software Help. I'm new to this.
    Mar 2005
    461
    If you have the "solids" add-on you can use Xform Rotate and Xform Translate to relocate the solid as desired.
    Most users, however find it easier and wiser to leave the solid where it is and create a new WCS at the new orientation and origin. This can be done whether you have the solids add-on or not.
    You can learn some helpful techniques here... http://www.mastercam-cadcam.com/sample1.zip
    Mar 2010
    Model Alignment
    Hi Matt,
    Thanks for the information. That's what I have been doing so far but I thought that maybe there was a technique to take a plane and simply match it to an axis and get an automatic, precise placement. So far I've just measured the angle if possible and rotated accordingly. Some models make this a bit tedious method though. I will look at the link to see if that helps.
    Stephen (I appreciate the logo)
    Mar 2005
    461
    The new "Dynamic Planes" feature introduced in X4 is quite helpful in reducing the tedious parts of this. It's not quite everything it should be but it helps a lot.
  1. Editing Solid Models In Esprit
    By thebowman in forum Esprit
    Last Post: 01-24-2011, 01:19 AM
  2. turret not aligning
    By gabby in forum Cincinnati CNC
    Last Post: 01-30-2010, 12:07 PM
  3. Fadal 15 solid models
    By robyc01 in forum Fadal
    Last Post: 11-19-2009, 04:18 PM
  4. Looking for solid models of a couple of threadforms
    By youngjim in forum Mechanical Calculations/Engineering Design
    Last Post: 09-20-2009, 10:49 AM
  5. aligning two objects
    By erase42 in forum BobCad-Cam
    Last Post: 06-22-2006, 11:07 PM
