585,733 active members*
4,989 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Weight of "Bridgeport Series II Interact 2" milling machine
    Oct 2006
    181
    I need to know, fairly accurately, the weight of "Bridgeport Series II Interact 2" milling machine. I need it in order to securely handle it, specifically I want to make a base for it on casters. I want to pick the right materials to make the base that would handle the weight.
    And definitely I do not plan on operating it on casters -- I would prop the base with 2x4s to relieve casters and make the mill secure. But I will need to move it as I work on it.
    So... anyone knows how much these machines weigh?
    Mar 2004
    369
    Quote Originally Posted by ichudov View Post
    Series II NON-CNC machines are listed as a shipping weight of 4750 Lbs. in one catalog, in another it is 5500 Lbs. Their 1974 catalog lists the Series-II CNC at 7200 Lbs shipping weight. This is a TAPE NC system, with a separate cabinet for the control. I'm guessing this even predates the BOSS control. Your machine is probably a bit less than that.
    Jon
    Nov 2004
    3028
    Per manual 11040804 for a Series 2 R2C3 with a TNC 145 control (same as a interact 2 series 2 but made here and not the UK) the gross shipping weight with skid was 5500 pounds and height was 96 inches.
    George
    Nov 2004
    239
    I'll believe the 5500 lbs. I bought mine in Houston and towed it home with an GMC Envoy and a tandem axle trailer. Nightmare.
  1. First Machine HELP...24"x36"x4" or Larger Setup w/ Gecko for under $3000
    By buschhoff in forum Want To Buy...Need help!
    Last Post: 03-21-2010, 12:37 AM
  2. "Gross Postioning Error A" Doing M03 on Bridgeport Interact Series 1 Mk2
    By MeTri in forum Bridgeport / Hardinge Mills
    Last Post: 12-28-2009, 06:37 AM
  3. How do I "Traverse Axis"? Bridgeport Interact 1 Mk2 TNC 155
    Last Post: 12-28-2009, 12:10 AM
  4. Determining "speed hole" spacing and size? (weight saving cutouts)
    By douglasco in forum Mechanical Calculations/Engineering Design
    Last Post: 08-04-2008, 09:26 PM
  5. Bridgeport Series "I" will not home, please help technical school in need!!
    By phantomcow2 in forum Bridgeport / Hardinge Mills
    Last Post: 12-16-2005, 12:11 AM
