585,978 active members*
4,209 visitors online*
Results 1 to 6 of 6
    Apr 2005
    53
    Backlash Compensation
    Hello, I seen some websites to this address, so I figured I give you a
    shot. I have a 1993 Toyoda horizontal milling machine with a 15MA
    Fanuc controller. Could you or any of your buddies send me some info
    of how to set the parameters for backlash compensation? I have about
    12-13 microns of slop in my X axis. I don't know how to get rid of it,
    someone said something about adjusting a parameter. Please help..
    Brian
    [email protected]
    24221
    Do you have the parameter list, it's in the 'Operation Manual' look at parameter 1851 'backlash for each axis' procedure, you need to set the machine in MDI set the PWE bit =1 that is parameter 8000=1, after entering the compensation you need to set 8000 back to zero.
    Al.
    Albert E.
    Apr 2005
    53
    Backlash Comp
    Thanks Al, you are the Man. I am a newbie to this site, could someone tell me what PWE is please.
    24221
    Parameter 8000 bit 0 =0000000(X) is the PWE 'Program Write Enable' bit. It has to be set to a 1 to allow the changes of parameters.
    Al
    Albert E.
    Apr 2005
    53
    Ok, I'm starting to get it now. My next question now is, how does the controler know I want to change the X axis and not Y or Z?
    24221
    It's a while since I set it on a 15, but the information gives one parameter 1851 for each axis, so I am guessing when you look up P1851 it should hopefully list the different axis present.
    setting range is -9999 +9999.
    Al.
    Albert E.
  1. Ballscrew Basics
    By Swede in forum Linear and Rotary Motion
    Last Post: 04-05-2024, 08:10 AM
  2. Backlash with worm drives ?
    By andy_ck87028 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-02-2005, 11:40 AM
  3. Backlash comp: does other axis pause during?
    By lesd in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-30-2004, 08:05 PM
  4. Ballscrew or Backlash Compensation?
    By RXTurbo in forum Uncategorised MetalWorking Machines
    Last Post: 08-05-2004, 11:47 PM
