585,938 active members*
3,282 visitors online*
    Mar 2010
    CNC Machine time rental?
    not sure if this is the appropriate forum, but I am wondering if there are any places (Los Angeles, CA specifically ) or close by area, that rent machine time on a haas or similar production grade cnc mill (3 axis is fine)?
    Don't know if places out there even offer this kind of service, I have designed some parts that I need to do a run with, everything is ready to run, I can mill the parts myself on my machine, but I don't like to babysit a desktop mill for 5hrs for a part. and my loan for a Haas VMC is not quite approved yet I have looked online as well and everyplace I got a quote was insane compared to doing it myself. so has anyone run into such a situation? what are the options out there?
    thanks in advance!
    -Andy
    Jan 2008
    449
    Tech Shop does but they are in No Cal and I believe they are going under. I doubt anyone would rent machine time to a stranger when a misplaced decimal point can cause thousands of dollars of damage. Mill work seems to go pretty cheap here, so I would just post an RFQ on this site. A lot of desperate people will bid machine time down below $20 an hour. You can't even get a gardener for that.
    Mar 2010
    Thanks for the info, I was pretty much expecting that, going to put together
    a proper RFQ and post here...
  1. time to machine materail
    By billlaws in forum Mastercam
    Last Post: 02-20-2010, 06:39 PM
  2. Machine (cutting time) V22
    By jensen in forum BobCad-Cam
    Last Post: 02-18-2009, 11:09 PM
  3. open machine time
    By Arty 3000 in forum Employment Opportunity
    Last Post: 12-30-2007, 07:41 PM
  4. Advertising CNC Machine Time
    By David M in forum Employment Opportunity
    Last Post: 05-18-2007, 03:25 PM
  5. Filling machine time
    By zachf in forum CNC Machining Centers
    Last Post: 04-06-2006, 01:50 AM
