585,977 active members*
4,115 visitors online*
Results 1 to 19 of 19
    Mar 2010
    Question GE Fanuc Series OM Controller
    Hi! I just got a drive unit repaired for a fourth axis (C) on a Komo VR1005 TT Router and need to check if it's working ok. I have never seen the fourth axis on screen, and from fanuccncamerica they told me which parameters change to enable the fourth axis. Now, I've tried to change them but I can't remember how to do so. I know it sounds silly, but can someone please guide me through this procedure? What should I do before changing the parameters? In edit mode or MDI, I can't get to change them! What am I missing?
    Thanks a lot!!
    Otto W.
    Jan 2007
    83
    You have to set the PWE bit to one. Doing so will cause an alarm which you can ignore until you have set the relevant parmeters.
    24221
    And in MDI.
    Al.
    Albert E.
    Mar 2010
    Question Cannot see 4th axis displayed, servo drive not ready
    Hi, thanks a lot for your replies. I've set the bit 12, made it 0, bit 1005, made it 0, and bit 1023 and made it 4. Turned off and on the machine, but there's no 4th axis, and the servo drive unit is showing the sign for "not ready". Tryung to see if it worked someway, I disconnected the unit, but there was no alarm or message on screen. Unfortunately, I have never seen this axis working in the machine (for the last 8 years) and I have no info regarding this problem.
    Please help me!!
    Thanks!
    Jan 2007
    83
    I am not sure what bits you are talking about. In my control, all of the critical bits are numbered 0 to 7. They are in addresses numbered 900 to 923 (or more, I am not sure). Is this a Fanuc 0MC?
    On my control, I believe bit 5 of parameter 913 turns on simultaneous 4th axis control. Bit 3 of 907 is turns on additional axis control. I am not sure if these are correct as I have not yet tried them on my machine. I would guess you don't need simultaneous 4 axis control - most can live with three axes moving at one time. So I would leave 913 off initially.
    Mar 2010
    Yes, is a GE Fanuc OMC. I will try it right away, thanks
    Mar 2010
    Didn't work, any other ideas?
    Jan 2007
    83
    Have you setup the servo parameters for that axis? If not you will need some manuals to do so.
    May 2009
    106
    which 0m cnc. a,b,c,d or 0ima,b.c,d ?
    Mar 2010
    9xx parameters
    ok, this afternoon I found the 9xx parameters for the machine, so tomorrow afternoon hope to set them. Regarding the servo drives, I do have the manuals (series OM Controller) but I really couldn't tell that I can do a lot with them without any guidance. Would you guys advice that I change the drive unit before any procedure? How could I tell the difference from a good one, if I have never seen it working?
    Thanks!
    Jan 2007
    83
    Otto-
    I have not yet set up servos on my machine, though I plan to add a 4th as well. I have the Fanuc manuals for this task that include the maintenance manual, the servo motor description manual, servo motor parameter manual, both connection manuals, servo amplifier manuals and I am probably missing some. For those of us without Fanuc experience, quite a few manuals are needed. Good luck.
    Mar 2010
    Question c axis enabled, but now shows alarm 1130
    Finally, changing some diagnostic bits, I've enabled the 4th axis. It seems to work ok, but a couple of things bother me. When a program is running, a lot of rumbe appears after a few seconds, then the 1130 alarm goes off. The rumbling disappears by turning the machine off with an emergency button. Turning off and then on the controller, and there's no problem, but then again, when executing a program, rumble appears along with 1130 alarm. When in jog mode, or homing, the machine works ok, so I disabled the 4th axis again, and the problem was gone, as well as the fourth axis. Any ideas? what should I do now?
    Jan 2007
    83
    What, specifically, did you change to make it work?
    Mar 2010
    Adjustments on diagnostics
    Bruce, I got the manuals and I found the original parameters of the machine, had to checked them one by one, manually. I found differences in: Parameter 0390, it was 00000001, it's supposed to be 00000000, but I couldn't change it. it changed after I turned the controller off and then on.
    Diagnostics: Switched 0340: 01000010 made it 01000011; 0341: 01010000 made it 01011000; 0393: 00000000, was supposed to be 01000000 but it didn't switch. It switched itself after I turned the controller off a couple of times to 00100000; 0394: 00001111 made it 00001011, but then it switched itself to 00001101; 0395: 00000111 made it 00000011. Before I switched all these diagnostics, I wasn't able to see on screen paramaters from 8400. Once I switched them, they appeared on screen, all of them according to the list. Anyway, now I have the 1130 alarm problem, that don't know how to fix!!
    Mar 2005
    816
    Might you tell us the FANUC part number of your drives?
    I have both 0T-C and 0M-C so I can help you a little bit, athough I don't know much about using the control with routers.
    Which servos do you have?
    Have you used the servo tuning screen(s)?
    Mar 2010
    Question spindle for c axis not operating
    Hi, I finally got the c axis working, but now, when I call the tool, it doesn't start. Does anyone think it's wise to disconnect the tool and connect it into another terminal to see if it works? Or is it another way to check the spindle?
    I will check my drives numbers, and let you know.
    Thanks!
    Jan 2012
    GE Fanuc 0-M
    Hi
    can you give a copy of GE Fanuc 0-M manual I will appreciate that
    Nov 2011
    you can download fanuc manuals from below link
    CNC MANUALS
    Jan 2012
    thank you for this informations
  1. GN6 Series General Numeric Controller
    By cncnavy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-22-2009, 08:10 PM
  2. Fanuc 160i-M Series Controller
    By kevin08 in forum Fanuc
    Last Post: 07-11-2008, 03:05 PM
  3. Help with Bridgeport Series I with Textron controller?
    By rhemp in forum Bridgeport / Hardinge Mills
    Last Post: 07-13-2007, 04:55 AM
  4. Bridgeport Series I Boss 5 Controller
    By VIC H in forum Uncategorised MetalWorking Machines
    Last Post: 07-24-2006, 05:54 PM
  5. GN6 Series Fanuc Controller
    By CBMach in forum Fanuc
    Last Post: 08-16-2005, 01:46 AM
