585,557 active members*
3,326 visitors online*
    Jul 2004
    55
    Questions about timing belts & gears
    OK, I want to add some reduction to my DIY router. I have 360oz servos and THK 5mm pitch ballscrews. (300ipm rapids are scary!!)
    I'm thinking in the 3:1 range, and am checking out the McMaster catalog....
    I'm leaning toward 3/8"width, .2" pitch .... will this be adequate?
    How much backlash can I expect ? (near zero now)
    Will they need to be accurately tensioned ?
    Do I need a tensioner device (spring-loaded idler) ?
    Will they stretch ?
    How often will they need replacement ?
    Any input/ opinions would be much appreciated. Thanks
    If it ain't broke... fix it 'til it is.
    24220
    Check this site, they have design criteria and formula's etc
    http://www.sdp-si.com/
    Al.
    Albert E.
  1. Planetary gearhead vs timing belts
    By Swede in forum Uncategorised MetalWorking Machines
    Last Post: 03-28-2005, 03:19 AM
  2. Timing Belts
    By chas in forum DIY CNC Router Table Machines
    Last Post: 01-19-2005, 04:03 PM
  3. Cheap Source for Timing Belts and Pulleys?
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 09-10-2004, 12:41 PM
  4. pully gears and belts for servos
    By replicapro in forum Benchtop Machines
    Last Post: 07-22-2004, 10:23 PM
  5. Timing belts, gears, and ratios
    Last Post: 12-20-2003, 02:09 AM
