Hi.
I recently tested one of my 4 BLDC Motors which are driven by an VSD-XE 160.
I have put in all the motor data and when i start the test the motor is rotating. Im not sure however its acting like it should.
the motor i testing is one of thishttp://www.anaheimautomation.com/pro...&tID=96&cID=22 and the encoder is this http://www.anaheimautomation.com/man...%20Channel.pdf
this is what the test says when its done
the motors have according to the manuals 8 poles and i suppose i should have 5000 as PPR?
Is it something wrong or is the test designed to test just 4 poles?
the motor spins smoothly in maby 3 secs and then when its a half of revolution left it takes like 5 steps or something to complete the whole revolution. Is it suppose to be like this or is it something wrong with my setup? (i've have tripplechecked the cables and they are as they should).
