585,556 active members*
3,361 visitors online*
    Mar 2007
    168
    Citizen F-20 Turret Alignment
    I recently purchased a Citizen F-20. I noticed that the turrets are off alignment by being rotated slightly (usually from a previous crash). I have done this type of alignment on other citizens, but this one is different enough that I would like to have some guidance before I go tearing into it. Any suggestions would be appreciated.
    Jul 2008
    29
    There are 5 6mm scerws under the number plate on each turret.
    Break them loose and you can tap the turret back into alignment.
    Mar 2007
    168
    bmngator, thanks for the info. How do you indicate the turret into alignment? Given that the bushing and the turrets move together in Z, it is hard to get an indicator in there to align with. The only thing I have thought about is putting a piece of ground stock through the bushing and clamp it into a drill holder while the turret is at X0.0. You could then just clamp it down. Does this sound like it would work?
    Jul 2008
    29
    I use a mag base cylinder that i put where i have removed a tool holder. I put a mag base indicator on the guide bushing housing and tram X + & -. If you have a cross drill holder you can do the same thing by indicating a drill blank mounted in it.
  1. turret alignment on sl 40
    By cherokeechief79 in forum Haas Lathes
    Last Post: 03-23-2010, 11:56 PM
  2. Mori SL3-H Turret alignment
    By JL Fabrication in forum Mori Seiki lathes
    Last Post: 07-24-2009, 02:26 AM
  3. SL20 Turret Alignment Help?
    By kend in forum Haas Lathes
    Last Post: 09-28-2008, 04:26 AM
  4. need help with turret alignment
    By wonder in forum Calibration / Measurement
    Last Post: 07-25-2008, 10:37 PM
  5. sl-30 turret alignment
    By bowhunter in forum Haas Lathes
    Last Post: 12-06-2007, 03:49 AM
