I need help getting my machine moving.
Short story:
Just got it in my garage and powered. Last night I had A/B flashing between STP and LSK and it wouldn't move. Today on power up it says "MMON (FC230B card) system go unready"
Long Story:
I have zero machining center experience I just new I wanted one. I have a BP series one and a home built router both running MACH 3. I saw the machine running before I bought it. Trailered it 300 miles. Removed Z axis servo, tool changer motors, and dropped the changer arm, and z axis down to get it through the garage door. I built a 40hp phase converter using a WNY kit. On power up, I had an e-stop warning that wouldn't allow the amps to power up. I went through the schematics and found the y axis limit was tripped. Manually turned axis off limit. The servo power would come on. Machine gave encoder battery error that went away. I couldn't get it to move. I tried jog, rapid, handwheel. Nothing worked. Today it says MMON (FC230b card) system go unready and won't finish booting.
Any help would be appreciated,
Kevin
