Hi I was looking for a way to create pdf out of bcc V23 drawings to email what is the best soft ware to use if it can be done.
One of the best tools we recommend is the FREE CutePDF program from www.cutepdf.com
It basically installs itself as an additional "printer" ... in any program, Word, Excel or your CAD program ... you proceed as if you were going to print your document or drawing to a regular printer ... select CutePDF as the "printer" ... and anything that would have gone to the printer gets created as a PDF file to your selected filename and location.
It's free, installs easily and is easy to use. One of the best features is if it looks good on your printer, it will look the same in the PDF file.
Hope this helps ...
Real World Machine Shop Software at www.KentechInc.com
Thanks blue chip ill try this.
Here is the link for the one I use, again a free download and is also very good, just select as a printer and save out the PDF.
Very quick and easy.
http://sourceforge.net/projects/pdfcreator/
Regards
Rob
:rainfro::rainfro:
