I am using a Fanuc Series 18-M controller on a Takumi V10a milling center. The manual for the controller says the Controller type is 18MC.
I am capable of sending files to the machine fine, however when I try to receive I am getting nothing going to the PC. The Mill appears to be doing its job as it will flash "output" briefly till it completes.
I am using BobCad Predator software to send/receive. I tried using hyperterminal to see if I could get any different results but I don't completely understand how to set this up.
I checked to make sure that punch code setting was set to ISO.
Is the controller using the same channel parameters (stop bits, data, parity, baud rate) to send and receive? Or could there be a different channel set up to send files to a pc with different parameters?
Any advice will help!
Thanks!
