In the never-ending struggle to minimize the amount of way oil getting into my coolant, I am now focussed on the Lube pump. It was leaking badly from the drain plug, reservoir cover, and piston rod.
I put teflon thread tape on the drain plug and replaced the cover gasket, but I am still getting a lot of leakage past the piston rod seal. Has anyone had similar problems? Do you know if this seal is user-serviceable or if replacement seals are available?
Not an earth-shattering problem, I know, but I'd like to fix it if I can.
