584,871 active members*
5,427 visitors online*
Page 4 of 4 234
Results 61 to 78 of 78
  1. #61
    Aug 2008
    6
    mandolin igs file
    I NEED MANDOLIN IGS FORMET KINDLY HELP
  2. #62
    Jan 2009
    Hi everyone.
    I've just joined the forum today after coming accross it via a google search. I'm a luthier in england (uk) and have just purchased a set of Siminoff's f5 mandolin plans.
    I was going to create 3d drawings of siminoff's plans in Rhino so that I could use my cnc machine to carve the soundboard and back but having read through this thread, it seems this may be harder than I thought!
    Has anyone managed to create a 3d drawing and successfully cnc'd it yet? If so, any help would be very much appreciated.
    Steve
    Chapel Guitars
  3. #63
    Jan 2009
    Hey chappel
    Its much easyer to send your files to Pragmatic, theyll send you back the G code you need. http://www.pragmatic.synthasite.com
  4. #64
    Jun 2003
    2103
    Quote Originally Posted by System 4 View Post
    Hey chappel
    Well I believe the answer to your suggestion is the fact he doesn't have the files. That is what he is looking for.
    Mike
    No greater love can a man have than this, that he give his life for a friend.
  5. #65
    Jan 2009
    Quote Originally Posted by turmite View Post
    Mike
    Correct Mike, as of yet I havent started to draw it in Rhino. I dont want to spend hours on it if its not really possible or if there is someone out there who is prepared to sell/give me a copy?
    Steve
    Chapel Guitars
  6. #66
    Jan 2009
    Bump!
  7. #67
    Jun 2006
    6
    Can anyone share mandolin top and back file for shopbot with me
  8. #68
    Apr 2005
    47
    Ok gents, here is the g code for a mandolin f5 top. I will provide the inside and back soon. Use a 1/4 inch endmill for each file. Lots of hard work to get to this point so I hope you all appreciate the effort. Please let me know if you have any provlems with this code.
  9. #69
    Apr 2005
    47
    Having a bit of a problem uploading.
  10. #70
    Aug 2009
    9
    I'm looking for this too. My wife has been after me for 2 years to make her an F style mandolin. Thanks
  11. #71
    Mar 2006
    I can help. Using my ShopBot CNC, I have probed the tops and backs of several Gibson F5, A5 mandolins and a Gibson H5 mandola. I converted that process into .dxf files and using my ArtCAM software converted those to cut files.
    I can be reached at [email protected].
    Bret
  12. #72
    Apr 2007
    8082
    Quote Originally Posted by mredican View Post
    Rename the gcode filename extension from .nc (or whatever else it may be) to .txt and it will upload. Downloaders need to rename it back to the .nc filename extension.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
  13. #73
    Jun 2006
    6
    I dont Know if this will help any of you but here is a mandolin back file to load in your cad
    I also can save it in other file formats. Please let me know.If you need the sound board.
  14. #74
    Jun 2006
    6
    Heres a mandolin back file
    If you are looking for a 3d mandolin back to load in your cad program then here it is. I can send it in a different formats if you need me to.
    Attached Files Attached Files
  15. #75
    Mar 2013
    Im looking 3d f5 mandolin files if anyone is willing to share. thank you
  16. #76
    Jan 2018
    Re: Heres a mandolin back file
    I have V carve desktop. Do you have files for F5 mandolin? I can import 3d files but I can not make them in V carve desktop.
  17. #77
    Nov 2005
    938
    Quote Originally Posted by johhick View Post
    I have carve desktop. Do you have dxf files for F5 mandolin I can import 3d files but I can not make them in V carve desktop.
    The first thing to specify if F-style or A-style. A-style is easy since it doesn't have that scroll thing on the upper bout. I don't have either worked up yet. What do you use for CAD software?
    If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do?
    Steven
  18. #78
    Jan 2018
    Quote Originally Posted by sdantonio View Post
    I am using V Carve Desktop it can only create 2d but I am able to import 3d.
Page 4 of 4 234
  1. My Mandolin Surface Post in BobCAD V24
    By aussiegazza in forum BobCad-Cam
    Last Post: 11-26-2017, 04:41 PM
  2. corel.hpgl > sheetcam.tap > pronterface.g-code > slic3r.g.code> ramps 1.4 > H-BOT
    By thesignworks in forum Uncategorised CAM Discussion
    Last Post: 05-25-2014, 02:11 PM
  3. tradeing mandolin G coad
    By mandolinmaker in forum Musical Instrument Design and Construction
    Last Post: 07-12-2013, 09:41 PM
  4. F5 mandolin
    By bahed in forum Musical Instrument Design and Construction
    Last Post: 12-25-2010, 12:22 AM
  5. mandolin info:
    By guitarman818 in forum Musical Instrument Design and Construction
    Last Post: 10-18-2006, 03:01 AM
