585,715 active members*
3,887 visitors online*
Results 1 to 8 of 8
    Apr 2004
    79
    Question spindle alarm AL-11
    Looking at a machine to retro. On power up the spindle shows alarm AL-11. Is this to be expected as the control is dead or is it a falt in the drive. I think
    its a A06b-6055 series drive.
    Thanks Drew
    If I had something important to say it would be here.
    Jan 2010
    96
    Hello. The alarm 11 is indicating an overvoltage in the DC link cicuit or the regenerative circuit is faulty. Check the F5 and F6 fuses on the drive to see if they are blown. If they are blown you can try and just replace them and maybe just due to whatever they blew but fuses usually blow for a reason and this alarm usually points to blown transistor modules in the drive. There is a checking procedure from Fanuc for the transistor modules i can send you if you give me an e-mail and if they are bad they are pretty easy to change out yourself and save you some money on a service call. The other simple thing to check first would be the proper incoming power. It could also be the PCB board on the drive unit but most likely you have one or more blown transistor modules. Let us know if we can help more.
    Apr 2004
    79
    I know its been a while , but I could use that procedure. Post and I will send email
    Thanks Drew
    Apr 2006
    85
    hi all
    i also getting Spindle alarm 11 in my turning center. but sometime machine run normally . machine will be on alarm any time . within at start or after 5hr or 2 hr or any time.
    please help me in this. mains supply is 375v 380v and 388volts at 3 phase. and at the end of transformer supply is . 188 190 195 volts 50hz.
    m. shabbir
    [email protected]
    Dec 2016
    8
    Quote Originally Posted by CNCZILLA View Post
    Hi do you mind to share me the information regarding the issue above?
    [email protected]
    Jul 2016
    Re: spindle alarm AL-11
    Sir i have the same issue please help me. My e mail is [email protected]
    Unhappy Re: spindle alarm AL-11
    Buen dia, podria ayudarme con en manual para poder resetear alarma 11 del drive fanuc, mi correo es [email protected]
    Gracias me seria de mucha ayuda.
    May 2022
    11
    I know its been 12 years since this post, but if you are still out there and still have this info, any chance you could send me a copy? [email protected]
    Cheers
    K
  1. Replies: 4
    Last Post: 05-03-2019, 08:58 PM
  2. Hitatchi Seiki ht 30g 2213 spindle speed 0 alarm and 2246 cutting spindle alarm
    By nixwake2snow in forum CNC Machine Related Electronics
    Last Post: 05-07-2014, 05:24 PM
  3. spindle 1006 alarm with AL-09 on spindle
    By hell_pk in forum Fanuc
    Last Post: 03-04-2014, 09:58 AM
  4. 1992 VF2 Alarm 123 spindle Spindle Drive Fault
    By dafowfidy in forum Haas Mills
    Last Post: 05-14-2012, 07:32 PM
  5. 750 ALARM SPINDLE-1 ALARM DETECT (AL11)
    By PICMAN in forum Fanuc
    Last Post: 03-28-2011, 12:14 AM
