We have two Haas CNC mills, a TM1 and a TM3. Both are on the network, we basically dump programs on the CNC machines hard drive and run them from there. Problem is you can't edit programs on the hard drive. I went through the manual and looked through old posts but could not find a way to copy the programs from hard drive to memory. What I have found is the following information;
Select program in Hard drive
Go to memory, it shows the program below and the destination as memory
Press F2, nothing happens.
If I give it a program name say O0111 and save that, then try to type F2 it responds error no program name.
Does anyone have a good step by step on how to move programs from the hard drive to memory?
Steve
