585,741 active members*
5,228 visitors online*
Results 1 to 8 of 8
    Mar 2010
    Connect Cadet CNC Lathe
    Just wanted to do a bit of a poll and see how many of these machines are knocking around.
    Can I have a show of hands please of everybody that has one of these.
    Once I know who has them I will know more specifically who to target my questions at
    Dec 2009
    6
    Conect Cadet lathe
    hi all i have the connect lathe and mill but no software for the lathe
    does any one know were i could get a copy of it many thanks davy
    Jun 2006
    3063
    Is this lathe sold by Little Machines?
    Mike
    Dec 2009
    6
    hi mic
    i dont think so it was made in the 90s by connect for schools
    Jun 2006
    3063
    Quote Originally Posted by davybfast View Post
    hi mic
    Then you and/or the OP might want to try a different forum for your questions since this one is intended for machines sold by the Little Machine Shop company.
    The Benchtop forum might be a good place to start or run a search on the brand name and see where other users hang out.
    Mike
    Oct 2011
    We have one in our school here in newry, N.I. It has been gathering dust since the 90`s and i was told i need a old 386 computer to run the software.
    Feb 2021
    Re: Connect Cadet CNC Lathe
    Hi,did you ever get your lathe to run, I bought a lathe without software and was able to get it to run on an old windows 98 computer, i do have problems with offsets as the software i downloaded from a forum has left the conectl offset programme a read only programme.I was wondering if you could upload a copy of your software for me.
    regards Roy.
    Apr 2014
    Hi Roy,
    A bit late but it might help.
    The original DOS software runs very well using DOSBox X on a modern PC (mine is windows 10)
    I have used all the versions of DOSBox but I prefer X as its easier to set up.
    You can make DOS files read and write using the "attrib" command in dos or at the command prompt.
    Hope this helps.
    Regards,
    Keith
  1. Okuma cadet lathe Z problem
    By rob jerico in forum Okuma
    Last Post: 08-19-2013, 04:22 PM
  2. Shesto cadet / connect 121 - help!
    By scotty1 in forum Vertical Mill, Lathe Project Log
    Last Post: 12-20-2009, 05:06 PM
  3. LNC-8C (Cadet lathe) turret index
    By Voss_Machine in forum Okuma
    Last Post: 01-26-2009, 05:15 PM
  4. need help, conect cadet lathe
    By tangleha in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-09-2008, 09:28 PM
  5. okuma cadet lathe osp 5020l
    By bryanpackmac in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-26-2007, 01:36 AM
