585,754 active members*
4,057 visitors online*
    Jul 2009
    30
    mazak quickturn 20 hp 1996
    Hi.
    Im looking a buying a used mazak 20hp quickturn, 1996.
    just wondered have any of you had any experience with them.
    good and bad points please?
    thanks
    Jan 2009
    265
    Mazaks come into their own for batches of 10 to 500 parts (jobbing).
    They can do production obviously, but you pay a lot more money over a korean machine and the reason why is the 'mazatrol' programming is so darn easy and quick to use.
    Whoever wrote the code for mazatrol language really understood short batch machining.
    You can setup a chucking job super quick.
    Jul 2009
    30
    Quote Originally Posted by D.L View Post
    thanks for reply
    i have a mazak qsh10 twin turret cnc lathe but i dont use the mazatrol as it seems to add more time to cycle times.
    maybe as this mazak im purchasing is a later model it may be better.
    i will certainly give it a go.
    The first machine I ever worked on was a quickturn 20 hp. Wat an awesum machine I loved every second of it
    I want another one
    Follow me on twitter @GordoHogan or Check out my blog:
    http://cnc-programming-by-gord.blogspot.com
  1. 1982 Mazak quickturn
    By fer_mayrl in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-26-2011, 04:52 PM
  2. Is this Mazak QuickTurn 10 worth buying?
    By barchdesigns in forum Uncategorised MetalWorking Machines
    Last Post: 07-14-2009, 09:44 PM
  3. Problem with toolchange in Mazak Quickturn nexus II
    By Legenden in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-31-2009, 08:36 PM
  4. Problem programming my Mazak QuickTurn 15
    By revlimit in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-24-2008, 02:28 AM
  5. mazak t32-2, quickturn 8n
    By Enda in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-09-2006, 11:00 PM
