585,888 active members*
3,807 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > turned high speed off and can't turn it back on.
    May 2005
    94
    -yes parameter write is enabled.
    -yes I can turn on and off other parameters (stuff like large tool, conveyor, etc. so parameter writing does indeed work)
    -yes it's an option we own.
    -yes cycled machine on and off
    -yes used profanity
    Jul 2005
    12177
    I think you have to enter the activation code again. This should be written on the first page of the Machine Data print out in the manual. If you don't have the manual or if it is not there your will be able to get it from Haas if you give them the serial number.
    15362
    mishikwest
    When you do get it back on leave it on, it does not need to be turned off
    Mactec54
    May 2005
    94
    I turned it off in a futile attempt at tracking down this problem.
    http://www.cnczone.com/forums/showth...730#post756730
  1. High speed spindle... how high?
    By jonesja2 in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2015, 04:37 PM
  2. Replies: 15
    Last Post: 04-14-2011, 05:33 PM
  3. High Precision, High Speed Bearings
    By mikeyg in forum News Announcements
    Last Post: 09-08-2009, 01:06 AM
  4. High speed attachment for X4+
    By PEU in forum Syil Products
    Last Post: 04-26-2009, 10:40 AM
  5. High Speed Air Spindles
    By pebbert in forum Haas Mills
    Last Post: 11-04-2008, 05:20 AM
