585,894 active members*
4,157 visitors online*
Results 1 to 20 of 20
    271
    Ace Convertor
    Anybody really know how to use the converter? I was wondering when you click on PRIORITY after you have a DXF file loaded, What does CLOSE ENOUGH do? can you confinsate for the width of your cutter here instead of doing it in cad? If not then what does this do???
    My little piece of the web!
    http://users.adelphia.net/~wjdupont
    Apr 2003
    131
    Re: Ace Convertor
    Yeah, Doug's manual is a little terse.
    Close Enough controls what the delta is between two entities to be considered "joined" for the optimization. Optimization in this context means not retracting to Z between two entities that share an endpoint.
    There's no cutter comp in ACE, where the DXF lines are defines the toolpath.
    Best advice I can give is to draw a simple square, run it through ACE, then look at the gcode generated. That's how I learned to use it. Not a bad program once you get the hang of it.
    I'm trying to get the rest of the source from Doug so I can modify it a bit.
    Jul 2003
    5
    I keep hearing about ACE converter and going to the Yeager site to find it, but I don't see it listed anywhere there. I was beginning to assume it must be discontinued and is now pulled from that site, but since I see here this current post about it, I thought I'd ask . . . howcomzit I can't find it?
    Also, I can't think of anything better than for Mr. dkowalcz to be involved with it, I love your TurboCNC!
    If you find a fork in the road, take it!
    271
    downlad his trial version of cncpro and I believe its in there.
    Jul 2003
    5
    Thanks, Wood, I'll check that out!
    Charles
    271
    I have a problem that is really getting to me. When I draw something up in my cad prgram and then convert it over using ace converter, there seems to be alot of places in my gcode where my machine just hangs for a minute or so. anybody got any ideas. I would really like to fix this problem or at least solve it!
    779
    I think I placed it on the FTP site here as well.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    271
    why wont it read fonts from my cad program? i convert it with ace and nothing is there? any ideas.?
    779
    Fonts in most cad packages are not geometry. You must find a conversion utility or trace over the font with lines and arcs.
    271
    thanks
    2139
    I use Corel draw to do text, then select the text and convert to curves, then save a dxf file. Also I think the express tools pack for autocad (as found on the CD), will convert text to geometry as well.
    Eric
    I wish it wouldn't crash.
    Apr 2003
    292
    DeskEngrave is the best little program I've found for making text G-code. It's available here: http://deskam.com/deskengrave.html and it's free! Definately worth taking a look at if you want to engrave text.
    My name is Electric Nachos. Sorry to impose, but I am the ocean.
    http://www.bryanpryor.com
    271
    Ya i have that but it it limited .
    Apr 2003
    1079
    Woodknack, if I remember correctly, you are using turbocad? If so, if you use TrueType fonts, they can be exploded so they can be read by Ace - I think you will need to explode them twice, then Ace will cut them as a bunch of G01's. It's worth spending some time playing around.
    234
    Hi Everyone,
    Just got my machine running a couple days ago and have made some drawings (TurboCad) to experiment with. Sometimes when I use ACE Converter I get nothing in return. File is there but zero bytes. I have played with the settings and read all I can find about it but no help. Any one else have this problem?
    Thanks in advance.
    Marv
    Apr 2003
    1079
    You must make sure you save your drawings as Autocad v12, or Ace will do all kinds of strange things! Can't say I've had a file size of zero though?!
    234
    Thanks Kong,
    I'll try that. I have been saving them as DXF files and yea it's doing all kinds of strange things.
    Apr 2003
    1079
    I'm using Turbocad 7.1, so I save as DXF, then go into the setup section on the top right, and choose autocad r12 format in there. I'm sure you knew that, but just wanted to be clear. Hope you're not offended!
    234
    Kong,
    Actually I did not know that, thanks for waking me up. I just tried that and it looks like a real G-Code now. Thanks again.
    Marv
    Oct 2005
    8
    Woodnack, try outlineart. Pretty basic interface, but works for me. You can download from
    http://www.qwerks.com/allsoftware/O/3_software.html
    $20 to register
    Rgds, Lin
  1. TurboCad 6 vs 10.2 with Ace Converter
    By goodeye in forum Uncategorised CAM Discussion
    Last Post: 11-27-2007, 09:59 PM
  2. 0,0,0, UCS, and Ace
    By JW Peters in forum Autodesk
    Last Post: 04-12-2005, 01:02 AM
  3. Ace Converter G-code Question
    By ljoe1969 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-22-2004, 06:18 PM
  4. What to look for in a phase convertor?
    By CNC Pro in forum CNC Machine Related Electronics
    Last Post: 10-27-2003, 04:40 PM
  5. Tool Change
    By WOODKNACK in forum Uncategorised CAM Discussion
    Last Post: 07-13-2003, 03:26 AM
