585,744 active members*
4,136 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > macro for spindle speed variation
    Mar 2009
    Question macro for spindle speed variation
    Does any one have a macro for Spindle speed variation similar to the HAAS SSV commands?? I am turning a long thin shaft and want to eliminate chatter issues and speed up the cycle time to reduce costs.
    Jun 2008
    1511
    what kind of fanuc control are you using?
    Can you post your code on when and where you want to speed up the spindle?
    Stevo
    Mar 2009
    I can speed up or slow down any where but what I am looking for is a macro that will pulse the spindle +/- say 50 rpm as the cut is on going, similar to the HAAS ssv commands. I found that while the tool is in cut and I use the overides as it machines, to pulse the spindle manually this almost completely eliminates chatter and I was able to increase surface speeds and feeds, but I cannot be at the control for every part due to this is in a cell type setting and there are 3 other machines to tend to. Haas has commands using m codes to call up a macro to do this and cancel the macro but I don't have a Haas lathe at this time. Years ago I used the macro I am looking for, at another job, but lost the code that I had used and I am hoping that someone out there has a copy of similar macros.
    Jun 2008
    1511
    I posted this over in the other forum where you asked the samething but did not see a response so I am posting here as well.
    Not sure if this will work and I did not prove it out as I have no open machines right now. Another problem as already stated in the other thread this may stall at the increase and decrease points before moving the incremental distance waiting for the spindle to reach the specified speed.
    This is probably going to leave witness marks on the part at every #101 increment. Make sure none of these variables are being used for something else.
    We may have to do a macro interrupt to get the “IF” statements outside the WHILE condition so there is no waiting on variable changes that may be effected by the look ahead.
    #100=500(part length)
    #101=10(travel length before speed increase)
    #102=50(rpm variation every #101 distance)
    #103=300(spindle RPM)
    #104=#103(rpm counter)
    #105=0(counter)
    G0G90X()Z.1M3S#103
    G1Z0F50
    WHILE[#105LT#100]DO1
    G91Z-#101F50S[#103+#102]
    #105=#105+#101
    IF[#103GT#104]THEN#102=[-#102]
    IF[#103LT#104]THEN#102=ABS[#102]
    END1
    G0X()
    M30
    Stevo
    Mar 2009
    Thanks I'll give this a try as I remember this looks close to what i had but old age is catching up to me
  1. First Machine- Northboys yet another JGRO variation
    By Northboy in forum CNC Wood Router Project Log
    Last Post: 02-25-2010, 10:24 PM
  2. Constant cutting speed macro
    By MrWild in forum Dolphin CAD/CAM
    Last Post: 06-10-2008, 11:18 AM
  3. TL-1 SSV (spindle speed variation)
    By xyzcnc in forum Haas Lathes
    Last Post: 07-25-2007, 05:48 AM
  4. How to modify HPLG file to compensate for the speed variation of my laser engraver ?
    By g1zmo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-10-2007, 04:16 AM
  5. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
