584,841 active members*
4,543 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > WEB drilling with Fadal 4020HT
    Jan 2008
    16
    Hello all; I'm trying to drill a tube in two "X" locations. Right now the program is drilling as if it is a solid piece of material. I would like to speed the "R" plane threw the tube. Tube diameter is 1.660 with .140 wall thickness 6061 T6. 1/4 inch drill.Here is the program;
    N5 O572 ( AXLE WEB DRILL 2 HOLES 1/4 DRILL )
    N10 G20
    N15 G00 G17 G40 G49 G80 G90 Z0.
    N20 T1 M06
    N25 G00 G90 G54 X0. Y0. S1070 M03
    N30 G43 H1 Z1. M08
    N40 G99 G81 R0.1 Z-1.875 F7.1
    N45 X-11.312
    N60 G80
    N65 M05
    N70 G91 G00 G28 Z0. M09
    N75 G28 X0. Y0.
    N80 M30
    Thanks all I just got my machine back working since September 2009. Jerry
    Apr 2010
    If I understand you correctly, you want to stop drilling the air inside the tube? You could use two hole cycles instead of one, if you're intent on using the canned cycles.
    N10 G20
    N20 T1 M06
    N30 G43 H1 Z1. M08
    N40 G99 G81 R0.1 Z-.2 F7.1
    N41 G80
    N42 G5 Z-1.49
    N43 G99 G81 R0.1 Z-1.875 F7.1
    N44 G80
    N45 G0 X-11.312
    N46 G99 G81 R0.1 Z-.2 F7.1
    N47 G80
    N48 G5 Z-1.49
    N49 G99 G81 R0.1 Z-1.875 F7.1
    N60 G80
    N65 M05
    N75 G28 X0. Y0.
    N80 M30
    I think I would forgo the canned cycles and just g-code what you want it to do directly. But that's just me ;-)
    Apr 2009
    105
    Quote Originally Posted by chipwitch1 View Post
    +1 on G coding it. You could make it a label if you have multiple holes.
    Still working in the "D".
    Jan 2008
    16
    I will load the program Friday 04-09-2010 and see what happens. Thanks!
  1. Fadal 4020HT arcing
    By sullione in forum Fadal
    Last Post: 07-27-2009, 04:03 PM
  2. 1992 Fadal 4020HT startup Z and C axis errors
    By Gerald Sande in forum Fadal
    Last Post: 07-20-2009, 02:54 AM
  3. Fadal 4020HT general noob questions
    By MBX5 in forum Fadal
    Last Post: 06-22-2009, 03:28 PM
  4. FADAL 4020HT post processor HELP!
    By carbonraptor in forum Fadal
    Last Post: 01-17-2008, 10:52 PM
  5. Looking for a use 4020HT with rigid tap
    By REVCAM_Bob in forum Fadal
    Last Post: 05-13-2006, 07:50 PM
