Set up and goal:
Drafting with alibre. Using sprutcam 2007. Wanting to remove simple cylinder worth of material. Using pocketing to machine it. I have machined a few drafts with acrylic to confirm the code outputs the desired diameter.
Problem:
Diameter of my test acrylic run is never the diamter I intended it to be. I figure its just me experiencing a learning curve. I need help figuring out what my diameter of the final piece will be based on the g-code. I hate wating a hrs for a test piece to finish.
Im falling behind real quick on my project. Im a total newb.
Attached is one of my several failures. I thought I almost had it on this one when I saw the stock paramater setting.
