Originally Posted by
packrat
I'm just an old guy, but I don't see the need for a QCTP. With a lantern style tool post and a left and right tool holder I can do more cuts with fewer tools.
I know it's not a popular thing anymore, but a lantern style post is still viable.
cary
PS, yes I have both.
How old is old?
A quick change toolpost is all about productivity. I used the lantern style toolpost back when I started out 30 years ago, then a 4 way (which sucked most of the time because of tool interference), and then a multifix 40 position toolpost came installed on a used lathe that I bought. With no preconceived ideas, that multifix toolpost revolutionised the way I could work. This gives you almost as many positioning options as you get from a lantern style toolpost, but a lot more rigid, and the tools are out farther from the compound so you can get better access to the area near the chuck. Switch to any tool and back in 5 seconds. Also justifies the usage of a DRO, because of the repeatability. If you make more than one of anything, changing tools in the lantern is pretty much a waste of your day.
