There are a range of manual bench top presses available such as the MA Series III Clicker press and GrandeMARK roller press and would anyone have experience comparing them?
Does anyone have experience trimming a MA Series III press? Would it be realistic to cut a large die and expect to get a clean cut? Would you just shim the base if needed?
How would the maximum cutting pressure compare?
Are roller presses less problematic in achieving a clean cut on a large die?
