584,858 active members*
4,594 visitors online*
Results 1 to 9 of 9
    Apr 2010
    PARAMETER MAZAK SLANT TURN 30 WITH MAZATROL T1
    Hello ,
    I am a beginner for the CNC Machine and Just Bought used MAZAK SLANT TURN 30 UNIVERSAL WITH MAZATROL T1 CONTROLLER.
    The Battery died and all the Parameter are Loss.
    Please any one help me to provide the Parameter List for this Machine .
    Thank You ,
    Tonny
    24216
    Send me an email address by PM and I can send what I have.
    Al.
    Albert E.
    Apr 2010
    Parameter Mazak Slant Turn 30 Universal 1500
    Thank you Al .
    my email address : [email protected]
    Please also provide the OP Parameter.
    Apr 2010
    Thank you for the Parameter .
    I have loaded all parameter you provide to me but have problem with the tool change .
    The Tool Clamp can not clamp I think have some parameter are miss.
    please advise,
    24216
    This is all I have otherwise.
    Al.
    Attached Files Attached Files
    Albert E.
    Apr 2010
    Al,
    The first I loaded QT10 Parameter the spindle can run properly and no alarm appear on the screen but the Turret is always turn if I push the Tool Change Button ,after I loaded your Parameter the spindle have a problem over load alarm appearon the screen ,I change again the Parameter with QT10 but not working the spindle always trip alarm appear on the screen overload.
    Why ????
    Apr 2010
    Hello Al,
    Now the Machine can Run Manualy the spindle and both axis can working properly but when I trun to run the Program appear alarm on the screen 101 Missing condition.
    I have register the tool .
    Please give me some advise this problem.
    Thank you
    May 2010
    I would also be greatfull if someone could let me have a copy of the parameter list
    Toby
    Aug 2010
    T1 Parameters please
    Can someone help me with the Chuck Barrier, T data, T Set data for the T1. Having a hard time setting up the machine. Thanks.
  1. Need help with Mazak Slant Turn 15 Univ. / Mazatrol T1'
    By Haaatschi in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-11-2021, 01:33 PM
  2. MAZAK SLANT TURN-28
    By CHANDRU in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-09-2010, 10:45 AM
  3. MAZAK QUICK SLANT 20N MAZATROL CAm T4
    By jlviloria in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-07-2009, 03:14 PM
  4. MAZAK : SLANT TURN 40N / T-PLUS / 33 EMG STOP
    By iNUC in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-29-2009, 04:26 AM
  5. mazak slant turn 40n
    By intermax in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-04-2007, 09:16 AM
