Hey guys,
Someone help me figure out why my TM-1 won't spin above 750RPM in manual machining mode. Any tips are greatly appreciated.
Hey guys,
Key switch on the side of the control ??? Just a thought, we only have 2 TM's here.
Thanks but thats not it.
Check the gear mode, you could be engaging the low gear. 750rpm max seem to be is what manafacture suggested.
The best way to learn is trial error.
Do you have the safety switch override locked?
Setting 51...I think.
Tim
On a VF11 that I run the cable had fallen off, I believe it was the encoder cable. The funny part was the machine was only about three weeks old
If it will not go above 750 in either MDI or when running a program it could be a problem with the vector drive.
The Haas drive switches from Wye to Delta (or the other way around) at something like 750 rpm and this is done by a relay; possibly this relay is sticking in the low speed.
One approach I would take is to open the door on the control cabinet and gently tap all the relays with a small plastic hammer; this could kick something loose if it is just sticking.
If you choose to try this remember there are lethal voltages inside there so don't go sticking fingers in the touch things.
you are correct setting 51 needs to be turned on same for me TM3
