585,932 active members*
3,899 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Loosing step more and more on X axis only after reducing the accl/velocity step motor
    Feb 2005
    234
    Hi guys,
    I built this router for 2 years with no problem.
    now looks like loosing steps on Y axis only, this is the second time happening after I reduce the Velocity and Acceleration on the Step Motor.
    Could this the motor getting weaker ?
    How to tested ?
    or does the Controller is the problem ?
    thank you for helping me
    Cal
    May 2008
    85
    Make sure the Y axis coupler is tight. A loose coupler can cause problems similar to missed steps.
    Dec 2008
    226
    what sort of linear bearings, drive screw/nut... could they be wearing/binding
    Feb 2005
    234
    just checked, no loose coupler or anything
    Cal
  1. Step/Direction pins should be Step FWD and Step BACK
    By rayscott in forum Mach Software (ArtSoft software)
    Last Post: 02-10-2010, 12:57 AM
  2. step driver 5A and step motor 6.4A
    By gorantec in forum Stepper Motors / Drives
    Last Post: 02-13-2009, 01:20 PM
  3. Full step and half step hybrid driver?
    By rkremser in forum Stepper Motors / Drives
    Last Post: 11-20-2008, 05:22 PM
  4. why my step motor can't step faster?
    By xinzc28 in forum Stepper Motors / Drives
    Last Post: 07-19-2008, 04:13 AM
  5. How to code a step motor axis move?
    By Niggo in forum OpenSource Software
    Last Post: 08-14-2007, 04:40 AM
