586,005 active members*
5,181 visitors online*
Results 1 to 8 of 8
    Oct 2004
    15
    CNC Hot wire Foam Cutter
    I kust built my foam Cutter. Should have the electronics kit from hobbycnc tomorrow or Friday. I want to be able to cut planes out of FFF or Depron. I need some advice/Help doing this. Someone point me in the right direction.
    1st the drawing, 2nd the clean Up, 3rd the cutting. what is the 3 software that everyone uses to do each step or is there just 1?
    Thanks Krashlnd
    Nov 2004
    65
    here's a link to lots of information , although it's in french you should be able to follow it
    http://www.teaser.fr/~osegouin/
    it worked for me
    Dave
    Dec 2005
    Surprised no one bother to translate it yet (chair)
    Aug 2005
    300
    Hotwire foam cutter
    If you search Google for French Translation you will find many sites. Some of these will give a free, but rudimentry, translation. I think that the translation is good enough so that you can get the gist of the message.
    Ernie
    Jul 2005
    17
    Hi, did you say - electronics kit from hobbycnc - !!!!??? it's out of stock as the web page say!! I need same kit too
    from where you buy it ?
    Nov 2005
    6
    Purchase
    Looks like he posted in May 2005. I suspect he got it from HobbyCNC.
    Sorry for stating the obvious.
    Barry
    Feb 2005
    53
    If you need to translate anything, go to google.com and beside the search bar you will see language tools. here you can put in the web url and tell it what to translate to and you are away. You can also put in words from another language and get a meaning.
    Later
    Dec 2005
    Quote Originally Posted by Prboz
    Later
    Thx that may help
  1. Large CNC Foam Cutter
    By Clax in forum CNC Wire Foam Cutter Machines
    Last Post: 03-16-2009, 02:23 PM
  2. Replies: 6
    Last Post: 06-18-2005, 05:19 PM
  3. cnc hot wire plans wanted
    By chris69randy in forum CNC Wire Foam Cutter Machines
    Last Post: 03-12-2005, 03:03 AM
  4. Stepper motor for CNC foam cutter
    By Juancar in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2005, 07:23 AM
  5. home made CNC wire cutter and router
    By geesville in forum DIY CNC Router Table Machines
    Last Post: 02-06-2004, 03:24 AM
