Hi all.
Quazar had some great info and most of this is a cut and paste.
Been looking at the fourms and gathered some info on this upgrade with some confusion I hope someone may be able to help me out with. I have a R8 taper spindle and need to change all the spindle bearings with a good quality brand.
What I gather is:
Grizzly bearing 32907 (taper bottom) can be directly replaced with NTN bearing 32907XU.
Grizzly thrust bearing 8106 and radial bearing 80106 (top) can be replaced with an SKF 32006 X/Q using the thrust washer that had been between the thrust and radial bearings to fill the gap as a spacer.
Are this the correct bearings?
Where to buy them?
What grease to use?
Also I need to replace the top-most bearing (the one that the quill-pully is attached to)? Grizzly part number 80107.
Any number for a quality replacement?
Thank you
Artie
