585,555 active members*
3,044 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > DC motor control for 180v dc motor, will this work ?
    Jan 2007
    53
    Hi guys. My new Weiss wmd20 mill came the other day, and I blew the speed control board almost right away. The s6025L SCRs exploded. I replaced them, but there's no DC output to the motor. Maybe the d6025L rectifiers are broken, but I don't know enough about electronics and I can't buy those in England.
    While I await a replacement speed controller board, I was pondering how I might get the machine going, or even how I might do it if this ever happens again.
    I think (will check) that the motor wants 180v. Supply power here is 240v. So, would the following do the job for running my mill's motor? :
    Dimmer switch / triac, into a transformer with a ~125v secondary winding, into a bridge rectifier. In theory I'd get 180v DC with the dimmer switch all the way up, right ?
    Is that a good or bad idea ? I know very little about electronics. Would there be an issue in that low-speed would be missing torque that would come from a proper speed control circuit ? Or might I find that the motor overspeeds anyway ?
    cheers,
    Carl
    24220
    The SCR drives made by KB or Baldor are 120v or 240vac for 90v or 180vdc motor, I am not sure if they are available in the UK but someone may make an equivalent, they are fairly cheap on ebay.
    Al.
    Albert E.
    Jan 2007
    53
    Al.
    Thanks. I don't see anything like that on eBay UK though. I suppose I could buy one from the US for next time..
  1. Cards Support Stepper Motor Driver Control & AC Servo Control.
    By Johnnyatcnc in forum News Announcements
    Last Post: 04-09-2010, 09:57 AM
  2. spindle motor and spindle control dont work
    By customcncparts in forum Milltronics
    Last Post: 10-01-2009, 08:08 PM
  3. Would this driver work with my motor?
    By eScott in forum Stepper Motors / Drives
    Last Post: 05-15-2009, 07:13 PM
  4. Will this DC motor work with this controller?
    By ZipSnipe in forum CNC Machine Related Electronics
    Last Post: 05-19-2006, 12:00 AM
  5. Will VFD work well on this motor?
    By jevs in forum CNC Machine Related Electronics
    Last Post: 02-28-2005, 06:29 PM
