585,589 active members*
2,923 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > Double head laser cutting and punching machine for shoes
    Apr 2010
    Product Feature
    It comes with two sets of high power laser sources. It not only can work with single head in the whole area but also process with two heads at the same time. With a structure of mobile electric constroller, the distance between two heads can be adjusted at will. By this way, it saves material greatly.
    Pedrail working table and porper woking area for shoes makes it a professional machine in shoes processing industry.
    Application Field
    Suitable for all kinds of fur,leather fabric.
    Technical Parameter
    Laser type CO2 Hermetic and detached laser tube
    Laser power 80W×2/100W×2
    Cutting area 1400mm×900mm
    Cutting(no-load)speed 0-30000mm/min
    Repeating location ≤0.06mm
    Moving system Offline moving control system
    Cooling system Close loop water cooling system
    Working table Pedrail working table
    Laser power adjustment 0-100% Following laser power adjustment
    Repeating location ≤0.1mm
    Power supply 220V±5% 50Hz
    Format support AI,BMP,PLT,DXF,DST etc
    Standard collocation 550W exhaust fans, mini compressor
    Select collocation High pressing blower electromagnetism valve and controlling board, water chiller
    Samples
    Apr 2010
    IF any one is intreseting in this kind of laser cutting machine, please feel free to contact me by:[email protected]
  1. CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!!
    By oliver9866 in forum Engraving Machines
    Last Post: 12-15-2010, 09:44 PM
  2. Newbie needs help! cutting acrylic, and double cutting? 3040 machine
    By stephaniehamer in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-29-2009, 09:37 PM
  3. CNC punching machine recommendation
    By Lowe in forum Want To Buy...Need help!
    Last Post: 03-25-2009, 11:04 AM
  4. Supply Laser cutting machine and Laser engraving machine
    By sherryguo in forum News Announcements
    Last Post: 11-27-2007, 02:47 PM
