585,575 active members*
4,016 visitors online*
    Oct 2007
    4
    EMC plus Exlar Linear Servos
    We are building a light duty assembly press, right now the though is to use Exlar linear servo drives for the press's motive force. Since this project is on a tight budget we looked at ebay and low and behold we found mostly what we want:
    http://cgi.ebay.com/Exlar-Linear-Ser...item439bb2c13f
    There are other exlar models that would work as well. We would need 2 actuators working together in tandem to provide the up down motion of the press in a master/slave configuration. The actuator positional accuracy is important otherwise the press will bind. Can EMC communicate with a Kollmorgen, Emerson, AB, Yaskawa... servo driver? With that said, should we use the specified servo amp or should we use EMC plus some homemade circuitry? If we would go the "rolll your own" server driver, how hard is it to build one? Are servos pretty demanding on using a specific driver? Finally does it make a difference if the servo uses a resolvers vs an encoder?
    WGB
    Feb 2008
    644
    Quote Originally Posted by KS_WGB View Post
    WGB
    Brushless motors (and in looks like the Exlar is brushless) usually require a matched servo amp from the same manufacturer. Rolling your own 3 phase servo driver is quite a project and likely a large distraction from you main task.
    That said, it is possible to drive most brushless motors with a generic 3 phase servo drive, but this will require some engineering and perhaps kludgery to figure out motor ratings, how the motor is commutated, convert the motors commutation signals to signals the drive understands etc etc.
  1. Linear Slides from PBC Linear Assembled in Underwater Drill
    By Pacific Bearing in forum News Announcements
    Last Post: 06-24-2009, 08:54 PM
  2. MLA Mini-Actuator: PBC Linear’s Solution to Bio-Tech Linear Motion
    Last Post: 05-07-2009, 07:35 PM
  3. Just saw a linear motor XY table with linear encoders today...nice
    By guru_florida in forum MetalWork Discussion
    Last Post: 04-29-2009, 01:39 AM
  4. PBC Linear Expands the PL Series by adding the PLB Linear Actuator
    Last Post: 03-06-2009, 09:58 PM
  5. Replies: 2
    Last Post: 02-09-2009, 04:28 PM
