585,996 active members*
4,544 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Hittachi Seiki NR III with Seicos A10L Hard Drive
Results 1 to 6 of 6
    Oct 2007
    19
    I have hitachi seiki NRIII with Seicos lambda 10 L, this problem can't start up now, after check i found the hardrive fail ( i try to change with other hardrive with same machine., and this machine can run ). I try to read This Hard drive using PC but unlucky, in Bios This HD can Detect, but on windows ( under disk management ) say...Unlocated . This machine using NEC PC-9800 with MS Dos 6.20, i also try to open this harddrive using DOS 6.20 but ..same can not read.
    What tool can i using to read this hard drive? please help me , thank you..
    Oct 2007
    19
    Smile Problem solved
    Dear all,
    my problem has solved, i try to clone this OK harddrive using freeware from internet. thank all.
    Sep 2012
    PB ON HITACHI SEIKI SEICOS A10L HARD DRIVE
    HELLO , I HAVE SEEN ON THIS FORUM THAT YOU ACHIEVE TO MAKE A COPY OF YOUR HARD DRIVE WHICH SOFTWARE ARE YOU USING , CAN YOU HELP ME
    Mar 2015
    Re: Problem solved
    Quote Originally Posted by andra View Post
    Dear all,
    Can you show me how to replate HDD
    I have same problem with you
    My NR23III lathe machine cannot startup because the HDD is faul
    I can Buy a new HDD but i haven't backup sys files
    pls help me
    Aug 2013
    11
    Re: Problem solved
    Hi Andra
    How to clone the HDD & what the software you are using?
    thanks
    regard
    harie
    Dec 2009
    539
    Re: Problem solved
    Harie
    is your HDD still good or has it died?
    John
  1. Hitachi Seiki VM40 seicos 2
    By bevins in forum Hitachi Seikis
    Last Post: 05-08-2013, 04:06 AM
  2. Hitachi Seiki Seicos
    By Enda in forum Fanuc
    Last Post: 12-15-2009, 06:14 PM
  3. hitachi Seiki VK45 with Seicos II
    By Dancy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-13-2007, 09:26 PM
  4. Hitachi Seiki Seicos Sigma
    Last Post: 04-18-2006, 09:49 AM
  5. Hitachi Seiki Seicos Sigma 21L
    By Enda in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-21-2006, 10:22 PM
