585,759 active members*
3,902 visitors online*
    Oct 2008
    driving LMD18245
    hello, i am learning to programme microcontrollers using assembler langauge. id like to make and programme a stepper driver based around lmd18245 and the pic16f1826. however ive had a look through the data sheet for the LMD18245 and i cannot understand the tables for how to drive it. what i know is:
    two chips are needed 1 for each coil
    each chip has 6 inputs from the microcontroller
    1 direction pin, 1 brake pin
    brake pin in my case will be kept low
    then there are 4 pins, m4,m3,m2,m1
    if anyone could possibly help me to understand what state theese 8 pins need to be in for step 1, step 2.... for full stepping?
    sorry if this has been coverd before i did look for threads about the lmd18245 but i could not check everyone.
    thanks for you time
    -calum-
    Feb 2009
    1290
    The PicStep uses both the LMD18245 and a PIC you might want to start there. While the AvrSTMD uses the LMD18245 and an Atmel uC. I think the code is the opensource for both.
  1. LMD18245 picstep need help
    By zoltan in forum CNC Machine Related Electronics
    Last Post: 02-10-2010, 02:12 AM
  2. When driving the Y axis....
    By Jkountz in forum DIY CNC Router Table Machines
    Last Post: 01-28-2010, 02:43 AM
  3. voltage LMD18245
    By kboudy in forum CNC Machine Related Electronics
    Last Post: 12-10-2007, 05:05 PM
  4. Driving Xylotex with PDA
    By Sanghera in forum Xylotex
    Last Post: 04-29-2007, 04:32 AM
  5. lmd18245 or sla7051m
    By TinkerDJ in forum Open Source Controller Boards
    Last Post: 10-29-2006, 12:40 PM
