585,996 active members*
4,222 visitors online*
    Sep 2007
    34
    Turn spindle chuck unclamped
    Hi all,
    On a SL10,
    Is there a way to turn on the spindle at say 20 RPM with the chuck (5 C collet) unclamped?
    I will be running some small step bushings on the backside and there isn’t much to grab onto when they are finished ,
    so if I could turn the spindle a few times they would fall right out.
    Thanks Erich
    Aug 2009
    235
    1: hit the emergency stop
    2: go to settings
    3: turn setting 7 off
    4: go to parameters
    5: go to parameter 248 and set it to whatever rpm you wish
  1. Easy Turn Chuck Handle on TL2
    By Geof in forum Haas Lathes
    Last Post: 10-01-2009, 05:20 AM
  2. Spindle won't turn on
    By ranchak in forum Bridgeport / Hardinge Mills
    Last Post: 08-30-2009, 12:32 AM
  3. 7x Spindle mod and max chuck
    By Richard23 in forum Mini Lathe
    Last Post: 06-24-2009, 02:33 PM
  4. interact 4 spindle drive won't turn on spindle
    By 0041601 in forum Bridgeport / Hardinge Mills
    Last Post: 06-23-2008, 11:51 PM
  5. Replies: 0
    Last Post: 05-09-2008, 11:13 AM
