I have a mill equipped with westamp servomotors which are rated 90 volts 6 amps. Can I use the 340 or 320 drive with these motors as long as the power supply is below the maximum voltage of the drive? What would that voltage range be? The motors are on a large vertical mill. I am not looking for speed.
Thank You
John D.
