585,883 active members*
4,764 visitors online*
Thread: K2 QUESTIONS
    Mar 2005
    13
    Hi Guys,
    I read this whole thread learning new things with every post. I also have a servo 3925 machine with all the axis on thompson rails and ballscrews on the x+y. I am a CNC rookie.
    My machine was seriously beat up in shipping. We had the machine crated and sent nearly assembled by freight truck. K2 did a decent job crateing the machine but a lazy driver litterally pushed it out the back of the truck. Absolutely brutal handling. With a little luck, the freight company may have bought a good portion of this machine for me.
    I have a couple questions....
    How quiet should the ballscrews be? It seems that they are making a bit of "tinking" noise at 75 - 150"/min. Should the machine just make a "whine" noise when operating? I am not sure if the shipping damage is causing the extra travel noise. I lubed the ballscrews with lithium grease. I do NOT think the X or Y is bound at all, powered down I can spin the axis fairly easy by hand, even with the belt on. I can even push the carriage and the servo motors spins... I think the axis is free enough, but I am worried about the noise. The Z is dead quiet even though the lead screw is bent.
    Is the best method to ensure a flat base surface to simply routing a wood base flat? By chucking up a 1/2 end mill and making a zillion passes this will create a perfectly calibrated Z axis base plane. Is there a better way?
    I have the Hitachi 12V router and I am looking for a 1/8th collet without using the spacer collet in a 1/4 inch unit. Does anyone make a ope-piece (no adaptor) 1/8th collet? Will a Porter Cable or Makita work in a Hatachi?
    Using MasterCam and Mach 2, it seems that there is some kind of post-processor issue when completing a drilling sequence. It seems that after canning the drill cycle (G80), it starts to contour without lifting the z and initializing a rapid transit movement (G0). Any one have any tricks to fixing this issue? Right now it requires manually adding a G0 after every G80 to rapid jog to the start point of the contour cycle.
    Are most of you using soft limits? Or do most put micro switches at each end?
    I am sure I will have some more questions, thanks in advance for your information.
    Mark
    Feb 2005
    921
    I have a 3925 machine also and my ballscrews are pretty noisy also, Im not sure if they are suppose to be though.
    May 2004
    350
    Yes porter cable makes a 1/8 collet adapter. It isnt in any store you will need to order it from porter cable yourself, or a local homecenter can order it for you. And my machine makes all kinds of noise I have had my one for almost a year now with miminal problems. I had ken add a plasma table to my machine and he made me a holder for my plasma hand torch. You can chuck up a fly cutter to level your table real fast.
    294
    Hey guys,
    Same here. I was suprised at how noisy they can be. I did open mine up to clean them out and added 2-3 (I think 3) extra balls. They are3.15 mm and you might have some ball bearings you can cut to get the balls from.
    taus
    tauseef
    www.cuttingedgecnc.com
  1. Beginner Questions
    By dfranks in forum Waterjet General Topics
    Last Post: 06-12-2005, 04:40 PM
  2. Work has commenced, many questions
    By Tabor in forum DIY CNC Router Table Machines
    Last Post: 09-21-2004, 05:46 PM
  3. Some Gecko 201 Questions
    By mikie in forum Gecko Drives
    Last Post: 08-10-2004, 05:40 AM
  4. Questions for starting and a formula ...
    By elenabux in forum Uncategorised MetalWorking Machines
    Last Post: 07-17-2004, 12:54 PM
  5. A few honest questions
    By HuFlungDung in forum CamSoft Products
    Last Post: 06-16-2004, 12:24 AM
