585,605 active members*
3,310 visitors online*
    Jun 2006
    44
    Mitsubishi Freqrol FR-SF
    Hi Guys,
    I Replaced the power supply (SF-PW) on this spindle drive about 3 months ago and it was working fine for the last 3 months. For the last 2 days the machine would just stop in mid cycle with a spindle controller error on screen. I powered off and back on and it worked for a while. then it stopped working completely.
    The spindle drive LED's are all off . On closer inspection I un-plugged the 3 black therminals from the right side on the back of SF-CA Card. Powered up and all LED's working. I plugged back in the Terminal strips one at a time and it's only when the top one is in that the LED's go out. So the top Therminal strip is pulling the drive down. what can I do ? Should I try and trace where the wires from this strip are going, should I check or look for anything in particular ? I'm attaching a few pics. In the second Picture with the top therminal strip left out it's fine and the front shows whats in picture 4. When I plug in the top Therminal Strip as in picture 3 all the led's go out. The power supply LED goes down with the Card LED's too.
    Attached Thumbnails Attached Thumbnails 6.jpg   Fine with just these 2 plugged in.jpg   Top Strip of wires pulling drive down.jpg   Without top therminal strip plugged in.jpg
    Jul 2007
    284
    It is definitely something connected to that third connector. The power supply has a safety circuit that shuts it down any time it sees a short. Something in the base has been shorted and probably needs to be replaced.
    Feb 2010
    46
    Quote Originally Posted by mbpp View Post
    Hi Guys,
    Hi there, check for any lose connection or breakage on your cables which is comming or going out from the controller and after all check your capacitators at the back of Spindle controller unit one by one (Be careful and discharge them first).Cheers
  1. Mitsubishi FREQROL problem
    By eva_1686 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-11-2020, 04:24 PM
  2. mitsubishi Freqrol-fr-sf spindle drive unit
    By mookh1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-06-2010, 07:05 PM
  3. Boxford TCL160 interface to Mitsubishi Freqrol drive and a few other questions
    By M100 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-24-2009, 12:58 AM
  4. Cable for Mitsubishi inverter Freqrol A 500
    By Tahir Iqbal in forum Community Club House
    Last Post: 07-25-2008, 12:00 PM
  5. Replies: 1
    Last Post: 10-09-2006, 06:19 PM
