585,597 active members*
3,535 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Trying to use "user M functions"
    Apr 2006
    19
    There is probably a simple answer to this, but it is eluding me
    I have installed the proper 120VAC relays on the 1100-1D board to use the USER M functions (M60-69). I am trying to get a response from the M60/61 relay. I have installed the fuse, the jumper to get the 120V supply to the relay as outlined in the (March 03) Maintenance Manual, section 9, page 341. I have a light bulb wired to the output just to see if I can get it to switch on and off.
    But no such luck.
    When I manually input common M codes such as M7,8,9, I get the code listed in one of the middle "active code" box on the screen showing that code as active. I don't get any such indication that the code is active when I input M60-69.
    Is there a setup or command variation that I am not doing right?
    Thanks in advance for any help!
    Robert Paisley
    2000 VMC3016
    Upland, CA
    Apr 2006
    19
    update
    More info on this:
    I just figured out there are little LEDs on the relay board that show which M code relays are active. In fact I AM getting ON/OFF indications from the LEDs for M60/61. So I must have a downstream wiring issue.
    (time for the voltmeter!)
    Robert
    Apr 2006
    19
    Boy do I feel stupid!
    Everything was working except the switch was turned off on my clip light that I was using to test the circuit ouput!
    I guess simple problems are the best ones to have!
    Robert
    900
    Welcome to the club! Anyone that says that they never did something like that is a lair!!
    Neal
    Apr 2006
    19
    Thanks for the support Neal!
    At least I got a good laugh out of it (at myself!)
    Robert
  1. Replies: 17
    Last Post: 11-20-2020, 09:48 PM
  2. I NEED a V2XT DX-32 " User Manual " BAD!!!
    By v488 in forum Bridgeport / Hardinge Mills
    Last Post: 03-17-2008, 11:53 AM
  3. Replies: 2
    Last Post: 01-25-2005, 05:26 PM
