Originally Posted by
pfred2
Whats bad about carbide, other than how brittle it is, is the fact that the stuff never gets nearly as sharp as HSS does. Of course whats great about carbide is it takes a really long time to get any duller than it starts out as. That, and it can take a heck of a lot more heat than HSS can too.
As long as you aren't setting the wood on fire I'd imagine you could run small carbide tools about fast as possible. 300,000-500,000 RPMs if you could do it. You can generally push carbide about 4 times faster than HSS.
So, your 65K RPM isn't even breaking a sweat for your tools. The fastest spindle I have is a swiss high speed pneumatic die grinder and I think it tops out at around 120K RPM. Its cute though, it sounds like a little jet engine when it runs.
One thing I find a bit odd is that you say they charge more for smaller bits, usually with carbide more costs more, not the other way around. But then again their name may be Ridiculous Carbide for good reason!
