585,735 active members*
4,692 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Inverting axis in table setup makes no difference?
    Feb 2010
    21
    I'm setting up my new cnc machine. Motors, settings and controls work well, except my X axis travels the wrong direction. I tried inverting the axis in the table setup screen, have tried that setting as both false and true. I've clicked "apply", closed out the window with the "ok" button, stopped and restarted Kcam, all to no avail. I can't get the axis to read/move in the opposite direction.
    Any suggestions?
    Feb 2010
    21
    Well, here I am answering my own post, sort-of.
    I did get it to work by inverting the direction signal in the PORT setup, so it now works. However, this doesn't make sense to me, so if anyone can elaborate why inverting the axis in the table setup has no effect, I'd be greatful. I get why the direction signal inversion would send the table in the opposite direction, but this seems like a kludgie workaround.
    Thoughts?
  1. Inverting positive Z axis direction on a VMC?
    By Donkey Hotey in forum Mastercam
    Last Post: 04-27-2010, 12:35 AM
  2. reversing homing direction without inverting axis?
    By draughted in forum LinuxCNC (formerly EMC2)
    Last Post: 04-08-2009, 10:04 AM
  3. Rotary Table as 4th Axis (setup help)
    By fc911c in forum Mach Mill
    Last Post: 04-03-2009, 04:08 PM
  4. Table setup - Axis invert
    By horse in forum Uncategorised CAM Discussion
    Last Post: 02-28-2006, 03:45 PM
  5. What a difference a computer makes
    By jwatkins in forum DIY CNC Router Table Machines
    Last Post: 07-08-2004, 02:23 PM
