585,906 active members*
3,912 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Moving part using hydraulics or pnuematics
    Sep 2008
    5
    I've got a problem....
    I am trying to come up with a solution for machining a 97" long part using a vertical mill with a 84" maximum travel in the x-axis. As of now I am using multiple clampings in order to face both ends to length and drill two holes.
    I have thinking about using m-code relays to shift the part laterally along the x-axis in order to reach both ends. I am working with extrusions and tolerances are quite large so precision is not extremely critical. This sounds like a fairly easy task, however being a newbie I have never worked with m-code relays before.
    Has anybody had any experience with this?
    Other than purchasing a new machine, or using multiple clampings, are these my only options?
    Jun 2006
    247
    I used to machine features into aluminum extrusion in excess of 100 inches on a table only 40 inches wide, sometimes requiring 3 shifts.
    My tolerances were wide also, so I just scribed a center line in the aluminum and lined it up visually with a full-point countersink in the spindle. After I shifted the part, the c-sink was programmed to rapid down, then feed to almost contact the scribed surface so I could line it up and re-clamp.
    I know you're dreaming of a more automated solution, I did too, but I thought maybe my scribe-and-shift method would be less headache than whatever you're currently using.
    Sep 2008
    5
    I have a pretty decent 2 stage fixture with accurate offsets to each clamping position. I am looking for a more automated solution where I can get the part finished without reclamping again
  1. Replies: 11
    Last Post: 05-31-2010, 07:03 AM
  2. moving a part in the cambam field
    By wantsout in forum CamBam
    Last Post: 10-23-2008, 05:11 AM
  3. CNC & Hydraulics
    By anthony in forum Mechanical Calculations/Engineering Design
    Last Post: 05-06-2007, 04:48 AM
  4. Hydraulics:HELP!!!
    By IcutPoly in forum Fanuc
    Last Post: 11-12-2006, 12:01 PM
  5. Moving a part: which method
    By originator in forum Linear and Rotary Motion
    Last Post: 11-03-2006, 06:19 AM
