585,981 active members*
4,226 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > What are the screen resolution sizes you are using on your Mach3 computer?
View Poll Results: Mach3 Users, what monitor display resolution size are you using for Mach3 CNC oprerat
Voters
47. You may not vote on this poll
  • 800 x 600
    5 10.64%
  • 1024 x 768
    31 65.96%
  • 1366 x 768
    0 0%
  • 1280 x 800
    5 10.64%
  • 1440 x 900
    7 14.89%
Multiple Choice Poll.
Results 1 to 10 of 10
    Dec 2008
    33
    As the title says, what screen size resolution are you using for Mach3 operation? Im interested what monitor display size you all are using! Eg. 800x600px, 1024x768px, 1366 x 768px, 1280x800px, or 1400x900px?
    "I will not let you regret knowing me."
    I use a 15" LCD, with 1024x768 being the maximum. If I had a larger monitor, I'd run a higher resolution.
    Dec 2008
    33
    Gerry, so where do you place your monitor? In an CNC enclosure or open air?
    Jul 2006
    53
    The pool would be better if it included all the commonly available monitor resolution.
    For example 1280x1024 is the most common resolution for 4:3 aspect monitors in 17" and 19" sizes.
    As this is not a choice, I can not supply an accurate vote.
    Dave
    Open air, but I keep it covered with a towel when not in use, to keep the dust off of it.
    Oct 2009
    27
    1024x768; got an older touch screen unit (Advantech brand) off eBay. Apparently it's made for the medical field, it's pretty dust proof so it just sits in the open and gets cleaned once in a while.
    It's networked with "my documents" shared so I can send code to it from any other system. Then just open Mach3 and go for it.
    Edit: Hum... seems like I just replied to an old post... wonder why it comes up when clicking "New Posts" on top :/
    Oct 2008
    406
    Quote Originally Posted by SirSmash View Post
    Somebody just voted. That updates the thread date/time even though no new post has been added to the thread.
    Bob
    "Bad decisions make good stories."
    Jan 2006
    115
    Well since this has now been resurrected by someone voting I'll add my $.02 .
    I run dual 17" monitors running 1280x1024 each. the on-board video card of my Gigabyte F2A55M-DS2 motherboard allows me to have a 2560x1024 desktop and permits the program to maximize across both screens as if they were 1 (not all video drivers will allow you to do this). I have added touch screen overlay kits to both (Yes you can do touchscreen on multiple monitors) and am currently getting ready to build the custom screenset for this configuration.
    My monitors are housed in an enclosure. Its very much a work in progress, and I have moved since this picture was taken and the new garage is much cleaner than this terrible mess was.
    Attachment 224564
    Nov 2012
    1267
    Re: What are the screen resolution sizes you are using on your Mach3 computer?
    768x1024 (vertical monitor).
    Mar 2009
    296
    I do both 800x600 and 1024x768 depending on where I currently stay. I voted 800x600 since it's what I last used. I use whatever monitor I can get for free, prefer crt but benchtop real estate often forces me to use lcd.
  1. Sinumerik 810M CRT replacement with Computer Screen
    By globalrobotics in forum CNC Machine Related Electronics
    Last Post: 02-07-2014, 07:54 AM
  2. Run Mach3 10X on one computer?
    By lewanski in forum Machines running Mach Software
    Last Post: 01-19-2013, 06:56 PM
  3. Screen resolution problem
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-10-2011, 02:04 AM
  4. Microstep Resolution plus lead screws to config in mach3...
    By Rob27 in forum Automation Technology Products
    Last Post: 06-11-2009, 12:08 AM
