585,717 active members*
4,048 visitors online*
    Apr 2005
    55
    culprit: Printer Cable?
    Well I finally have all the pieces assembled, but I can't get mach2 to reset the Estop. after much fiddling, I'm wondering if it couldn't be the printer cable?
    Using a tester, Pin 1 on one end doesn't map to Pin1 on the other end (tiny little numbers next to the pins). Do I need some sort of special printer cable? And why would this not map directly pin-to-pin?
    I'm using bob campbell's breakout board. he supplied me with a ribbon cable with a parallel port connector (female) on one end, and a special socket of some kind that connects onto his board.
    I wired my printer cable inbetween.
    -anthony
    Apr 2003
    1079
    Yeah, sounds liek the cable. I don't know all the ins and outs of the cables, but go for a "straight through" cable and it should work fine.
  1. Using printer motors and drivers
    By NeoMoses in forum CNC Machine Related Electronics
    Last Post: 04-08-2007, 01:42 AM
  2. Encoder Cable Question(s)
    By murphy625 in forum CNC Machine Related Electronics
    Last Post: 03-06-2005, 09:00 AM
  3. Terminating Festoon Cable Shields
    Last Post: 02-28-2005, 09:00 PM
  4. Floppy Drive Cable Fiasco
    By Al_The_Man in forum Computers / Desktops / Networking
    Last Post: 11-25-2004, 06:53 AM
  5. Bob cad cable type
    By i228208 in forum BobCad-Cam
    Last Post: 05-19-2004, 08:10 PM
