585,727 active members*
3,815 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Help: Autocad 2000 (Autocad Error aborting)
Results 1 to 6 of 6
    May 2004
    83
    I have Windows Vista installed, all of a sudden when I open autocad and the startup small widow appears and I try to open a existing drawing or new drawing, a window informing fatal error unhandled with a bunch of letters and number comes up and when I click OK the whole program quits,
    I have uninstalled the program and reinstalled and it works OK, but a few days later I go to use the program and its got this error again,
    has it got something to do with Vista do you think?, and could any member please help?,
    ..........Edmund.........
    Edmund
    Mar 2006
    2712
    I had many problems with "drop outs" until I got rid of Vista. I installed XP-PRO and have not had 1 instance since. I hope "7" is as good as XP-PRO.
    Dick Z
    DZASTR
    May 2004
    83
    Quote Originally Posted by RICHARD ZASTROW View Post
    Dick Z
    Thanks for responding, yes I have XP on another computer and like it very much, I got the vista computer cheap and was told that to install XP would cause a lot of problems,
    Today I plugged a usb flash drive with autocad drawings from my XP computer and to my surprise it worked great, but as soon as I took the usb out and tried to open a drawing from the vista files I got the fatal error again,
    Do you have any opinion about my scrapping vista and returning to XP?,
    Edmund
    Mar 2006
    2712
    That's exactly what I did. In fact, this post is being sent from that same XP-PRO computer.
    Dick Z
    DZASTR
    May 2004
    83
    Fed up with Vista
    Richard,
    If I decided to revert my Vista computer over to XP home edition, do I have to clean my hard drive of Vista (should I buy a drive washer) before I load XP or can I just load XP onto the existing hard drive?,
    I'm not very computer knowledgeable?,
    Will I lose all my personal folders?, how can I save them?,
    Edmund
    Mar 2006
    2712
    Edmund, I have to confess, I didn't personally load the XP-PRO. The computer shop where I bought it did it.
    I believe they loaded the XP on the hard drive and entered all the settings etc. then erased the Vista.
    There are other members here far more knowledgeable than either of us who can jump in here and help you.
    I decided to use app.'s rather than figure out the operations going on in the electrons. I'd be like the kid taking alarm clocks apart. Besides, I'd rather spend my time using the appliance rather than tinkering inside it. LOL
    Dick Z
    DZASTR
  1. Autocad 2000 Move
    By N4NV in forum Autodesk
    Last Post: 03-23-2014, 03:30 AM
  2. AutoCAD 2000 to AutoCAD LT 2010?
    By 2kjettaguy in forum Autodesk
    Last Post: 08-15-2009, 03:33 PM
  3. Importing 3D from AutoCAD 2000
    By noisillator in forum Uncategorised CAM Discussion
    Last Post: 06-19-2009, 03:44 AM
  4. AutoCad 2000 DXF Question
    By Holmes_ca in forum Autodesk
    Last Post: 01-20-2005, 12:50 AM
  5. AutoCad 2000 Missing .dll file
    By E-Stop in forum Autodesk
    Last Post: 05-30-2003, 05:43 PM
