Hi
I run a routech 240 CNC router with a NUM 1040 contoller using AlphaCam ver7.0 I was given a plot of points 2" apart along a curved wall to mill some crown for. I digitised it using the points then turned it into a spline and then turned it into a geometry. I programed it using some rough cuts to mill out the waste and then used the "profiled" option to make it to the profile I needed. It worked great on the test I ran.( a single arc) but when I tried to save the digitised curve .pgm it gets to the part where it starts the profile cut and gives me a "Valve of radius of arc not valid" error and won't go any farther to save it. The arcs are created using IJ values. Has anybody seen this before? Hopefully someone can point me in the right direction
Greg Williams
