585,764 active members*
4,076 visitors online*
    Dec 2009
    10
    Smile 1999 Mazak FJV-250 with Fusion 640M Control
    Our shop is looking to purchase a used 1999 FJV-250. I'm just looking to get some feedback on this machine good or bad. I has a 4th axis already installed. Im also wondering if the control is capable of controlling 5 axis or if 4 is the limit.
    Mar 2005
    988
    I love the FJVs ... tough machine, fast and accurate with the double column. Haven't used one with a 4th but you'll want to look into making sure you have the work space you need for the work you're doing. The 250 is necessarily a "big" vmc after you put a 4th on it. The Fusion is a good control with lots of possible options so do look into those.
    As for a 5th... never seen one done so I can't answer that one...
    It's just a part..... cutter still goes round and round....
    Jul 2007
    284
    I'm pretty sure the most it will run is 4 axis simultaneous but I believe you can run more then 4, just not simultaneously.
  1. Mazak Mazatrol Fusion 640m- FH6000 - Alarm 391
    By riddmj in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-23-2011, 07:42 AM
  2. lost programs on fusion 640m
    By Jsheldon in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-13-2010, 03:57 PM
  3. Using DPRNT on Fusion 640M Control
    By marcwdci in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-12-2008, 04:21 PM
  4. Post processor for Fusion 640M
    By naytep in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-03-2007, 01:30 PM
  5. fusion 640m rs232 comm
    By camcutter in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-30-2007, 05:23 PM
