584,879 active members*
5,427 visitors online*
Page 2 of 3 123
Results 21 to 40 of 46
  1. #21
    Dec 2011
    Smile CNC Technician ,how do you do!
    [QUOTE=CNC_Technician;1047989
    Hi friend,can you help me ,that my 852478 program :978081,978583
  2. #22
    Feb 2011
    18
    redflower
    [quote=redflower;1049129][QUOTE=CNC_Technician;1047989
    Hi friend,can you help me ,that my 852478 program :978081,978583[/quote]
    Hello what do you mind? program?!!!
  3. #23
    Dec 2011
    Smile
    [quote=CNC_Technician;1049158]
    Quote Originally Posted by redflower View Post
    I need chip program of 978081 and 978583.
  4. #24
    Dec 2011
    Cool Victory!!!
    :banana:
    I made the machine work!!!
    It was all about dirty pins and bad contacts....for the moment it works well..from time to time it tells me that the rear cover is opened, but it is ok
    However...the tec files I have are not compatible with this machine. Anyone got the right tec files? Willing to share??
  5. #25
    Dec 2011
    Smile hello
    MY ROBOFIL 400 Display E672 NO AXIS References in set up system disks.how can anybody help me?
    How to clean the liner encoder of U or V axis? thanks!
    Thanks[/QUOTE]
  6. #26
    Feb 2011
    18
    NO AXIS Reference
    [/QUOTE]
    hello
    you do not need to clean the liner encoder !!! it's not safe work you want to do.
    Just do this work:
    1-go on Setup page.
    2-go on Refrence page.
    in Reference page you will see 5 axis X-Y-Z-U-V
    your U and V axis alarmed with a star single near each axis that lose Refrence
    just move u axis to end and go back very slow do this work for V axis, star single will not see and your machine will work correct.
  7. #27
    Dec 2011
    Smile thank you!
    [QUOTE=CNC_Technician;1053314]
    thank you ,cnc_technician;according to your method,the references are ok,but displayed E213:Z,W,or R with tilted wire.that I don't know how to operate it.
    and i need ROBOFIL 200 852478 CCU EXE chip program:978081,978583.thank you very mach.
  8. #28
    Feb 2011
    18
    E213:Z,W,or R
    [quote=redflower;1053656]
    Quote Originally Posted by CNC_Technician View Post
    hello
    your are welcome. for E213:Z,W,or R: move u and v axis to zero then start program (iso file). at first u and v axis must be in vertical position and then start. some times this problem is from Gcode file. please try again and told me.thanks.
  9. #29
    Dec 2011
    Smile
    [quote=CNC_Technician;1054124]
    hello
    The times are chinese new year.thanks for your help!
  10. #30
    Dec 2011
    Smile hello
    [quote=redflower;1056007]
    The quasion is the crash water pump switch was invalidated,and indicator linght don't lighen coinstantaneous,in my robofil 400.how can i do?
  11. #31
    Dec 2011
    Smile hello
    I need ROBOFIL 400 POST (robo.pst for mastercam X4 or mastercam 9.1),can anybady help me?email:[email protected],because when load program(*.iso),displayed:E001 invalid command.thanks!
  12. #32
    Dec 2011
    Smile
    how anybody can help me ?
  13. #33
    Sep 2012
    15
    Calling subprograms from command files
    Hi
    I have recently purchaced a 1991 Robofil 200. I have not purchaced any software as yet and transfering programs thru serial port.
    Problem is how to call sub programs from command files. I have the manual but it does not have S or G98 functions in which tec can be set and sub programs called. I have written a command program for rough and finish pass. Is it correct:
    TOF,D1,0.299 ; OFFSET FOR E1 FOR HT 8mm
    REX,E1,H8
    SPG,MEM:HEX16; calling program rough cut
    TOF,D2,0.134 ; OFFSET FOR E6 FOR HT 8mm
    REX,E6,H8
    SPG,MEM:HEX16 ; calling program for finish cut
    Does the machine stop after each program.
    Thanks any help will be appreciated
  14. #34
    Jan 2011
    32
    Re: Charmilles Robofil 200 startup
    Hello to all, i have a charmille robofill 100 and i have the error chargement#cks erreur format when i insert communication floppy and press charger. Any solution? thanks to all
  15. #35
    Mar 2017
    4
    Hi. I need some help. The company where I work bought 2 Robofil 200. Both are with dead batteries, so need to load firmware.
    Original Software disks are very bad, but it was possible to read 3 of them except AutoDiagnostic disk. There was 1 working (i'm not sure by 100%) among 4 floppy drive. I tried to load Communication Disk, floppy lights on about 1-2 sec then the text appears on the screen:
    Chargement#ILC Ereurre Format
    I have read this topic and other topics like this. I'm sure that original Communication Disk was overwritten (see it by Disk Editor and DOS with native languages is in sector 1 of track 0). I don't have another Robofil to format 720k floppy and, to found a very old PC is the same difficult. Formatting by modern PC even by DOS on Celeron 333 PC was not successful (I know that formatting is 720k, 80 track, 9 sectors and to close a square hole in 1.44 disk) . The same #ILC erreur format. I tried to connect Robofil floppy drive to PC but it didn't work. How can I plug and test it?
  16. #36
    Mar 2017
    4
    Update... 2 of the disks are originally formatted, so I decide to copy main file FH44.bx8 to one of them. And... Nothing. The same situation. #ILC error. There are two variants: 1. need original Charmilles Communication disk or 2. Floppy Drive is not working fine.
    I read that new2edm just formats a disk by Charmilles machine and copy files to it and it's working. One way out remains: FDD. The problem is that I don't know how to test it. I tried to connect it to 286 with ISA-multicard (HDD+FDD+Ports) today. The drive is spinning, LED is lighting, DOS boot disk is in the drive, but DOS said Drive NOT Ready. Give me a pair of advices, please.
  17. #37
    Mar 2017
    4
    I have loaded firmware at last, connected BOOT SECTOR of Charmilles Techno disk and firmware file (FH44.bx8) with Disk Editor software. There are the nuances:
    1. 720k floppy must be formatted on the same type of Robofil (100,200,400,600 or the same Roboform). Any PC, any DOS version formatting = #ILC erreur format. Only Robofil writes the necessary BOOT SECTOR.
    2. Firmware file (with .bx8) must be the first in the FAT table on floppy.
  18. #38
    Aug 2018
    hello
    Just do this work:
    1-go on Setup page.
    just move u axis to end and go back very slow do this work for V axis, star single will not see and your machine will work correct.[/QUOTE]
    Quote Originally Posted by alex_under View Post
  19. #39
    Aug 2018
    hi i need POCKET GUIDE ROBOFIL OPERATOR charmille 200 in french language thank you
  20. #40
    Feb 2020
    Re: NO AXIS Reference
    Just do this work:
    1-go on Setup page.
    thank you! you make my day!
Page 2 of 3 123
  1. Charmilles Robofil 4000
    By John Murphy in forum Waterjet General Topics
    Last Post: 11-05-2021, 03:18 AM
  2. charmilles robofil 440 post
    By JCrafton in forum Mastercam
    Last Post: 04-29-2014, 02:37 PM
  3. DNC CHARMILLES ROBOFIL 310
    By tecnomaqq in forum EDM Discussion General Topics
    Last Post: 01-17-2014, 04:34 AM
  4. charmilles Robofil 190 or charmilles Robofil 290
    By Fontez in forum Post Processors for MC
    Last Post: 03-12-2013, 04:48 PM
  5. Charmilles Robofil 300 question
    By rtuls35 in forum EDM Discussion General Topics
    Last Post: 06-15-2011, 06:09 PM
