I use slats for the bed on my machine. I have arranged the slots that hold the slats vertical so that there is a an "S" curve to the slats. By doing this, the cutting doesen't stay above the slats very long during a cut. If the slats are at square with the table you may find that much of your cutting is in a straight line that may be above the supporting slat. Slats set at an angle to the bed would give the same effect but simply by flexing the slat into the "S" shape lets me flip, move and rotate the slats for renewing the support surface. Mostly this is done for looks though because when the cuts are made through the slats it leaves the nail effect you mentioned and it doesen't take much for the support.
never set a pace that you can't maintain
Traveler
