I agree with montebelli, those would be the things to do! Oh, I forgot to tell you to check and make sure the numbers in the interface match the numbers on the label attached to the leg or axis.
Originally Posted by
Montabelli
check your axies for play, I have had it from both the thrust bearing popping loose from its collar, and the nut at the thrust bearing coming a little loose. be careful not to over tighten if it seems loose. I got to buy a new lead screw once because of that. if there is no play in the axis, then you will need to use the backlash compensation in the controller software.
If you make a square toolpath and run it on a piece of scrap big enough to make it easy to measure , then check for accuracy on each axis and then corner to corner for square you should be able top determine where any changes need to be made.
http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
